boostisgood
- 1988 FC3S TII
Nick, I think you me and Andy have ALOT to talk about next week, while Im out there.
Those are all at the forum cost. The retail pricing for those units will be slighly higher after the GB.02.5 P5 said:is there going to be a discount for the Injectors, WB, Boost Control for the GB as well?
You got it.boostisgood said:Nick, I think you me and Andy have ALOT to talk about next week, while Im out there.![]()
perfworks said:The tuning will be simple. WE WILL HAVE IT READY FOR YOU!
Just tell me about your mods and thats all. Injector size, cam upgrade FI , NA no problem. I will scale it for your particular application. The mapping will be premade by us. I will go into this further
Forgive the ignorance but what do you mean by " s*** onmy system"igdrasil said:perfworks -
I know this question may disturb you a bit and say "dont s*** on my system", but hell...Ill throw it anyway.
Suppose I want to tune with stock injectors, good for maybe 8psi without maxing out the injectors....can I then add an FMU maybe 4:1, 6:1 to raise the fuel pressure ang go up to 11-12psi maybe more?
Yes , Yes and more yes. It will correct itself, not tune itself.Captain KRM P5 said:so if I were to call you and say, hey Nick, i have a flyin protege turbo kit with a garrett t3, etc etc etc, and I want to run 10 psi, thats all you'd need to program an AEM. Then I'd plug it in, drive the car, and it would tune itself to adjust to certain variables along side any datalogs and adjustments that are traded over the internet?
sign me up for the paralell unit. plus, how exactly does the boost control solenoid on the AEM work?
There are parts of this post I will NOT touch.hukster00 said:can the Parallel system use speed density with a map and ait so no maf is needed or is full Standalone needed ?
One , the other and then both.hukster00 said:is the car you testing the ems on using maf or speed density ?
ViksMSP said:Everything sounds good, so I'm guessing I will also be able to run open-vent bov, and not stall, since the maps could be adjusted to fix that. Or do i still need to install a second valve to recirculate?
Thanks,
Vik.
Nope ONE BOV is fine.ViksMSP said:Everything sounds good, so I'm guessing I will also be able to run open-vent bov, and not stall, since the maps could be adjusted to fix that. Or do i still need to install a second valve to recirculate?
Thanks,
Vik.
Yes there is temp compensation for Air and engine coolant. Density, barometric pressure, volume and load will all be taken into account. Just like your stock unit.midnightracr said:Damn, All of this is sounding almost to good to be true.. I love it
I know u said it will self adjust so does that mean it will adjust to temperatures say like one day it's 30 degrees out and the next is 45. will it be able to crank and run strong in all temps
