Mounting Unichip switches
tricky
Ok so I finally got around to my original idea. What do you all think? they will mount next to the dimmer switch to the left of the steering wheel. I have a friend that is considering mass producing these if there is enough interest. It will be just the shell to hold the actual UC switch. Also the label can be removed or reversed color so it would be black background with white lettering, or no label at all. This is the first prototype and it's not perfect by any means but you get the point. I'm also thinking of moving the light down a little closer to the switch and putting the label above the light, not too sure yet.
Not bad.. Much better then just sitting in the glove box.
carbonkid said:
We should put up an installed pic next week...
yep, I will post up the finished look next week with all 3 switches lined up nice right next to the dimmer. I think we should look into reversing the colors of the labeler black background w/white letters if it's even possible. That might give it a clearner look as well.
Nice wedding ring.
Oh..and that looks pretty good. Did you dremel it out?
Rawyzf said:
Nice wedding ring.
thanks, it's titanium! Did I dremel it? no. I owe a big thanks to the steady hand of carbonkid!
Agreed. Easy, I just need to buy a black label cartridge.
Here is mine...now you know why I kept buying all the fog lamp switches available.
well yesterday I didn't have much to do so I finished the install and took some pics. For some reason the camera wouldn't focus quite right so I'll have carbonkid use his 10 megapixel camera to take better ones either tonight or sometime this week. again these are prototypes, I'm thinking I'd like to completely redo the switches, possibly use a different type of switch all together. I am please with the results, I just want perfection
onequickmsp said:
I noticed you have your Unichip off. Isn't it always supposed to be on??
to be honest I'm not too sure. obviously it's an ecu reset switch so either way I flip the switch and it should reset the ECU right? maybe someone else can correct me.
