Mounting TCM to brake lines to avoid overheating?
2015 Mazda 5 Sport
2015 Mazda5 with nearly 75k miles on it.
I am planning to do transmission fluid change soon. From reading up the posts and watching the videos on YouTube, I learned that one more common issue with pre skyactiv Mazda 3 and 5 is the TCM module being cooked from overheating because it is mounted directly on the transmission casing. Over the miles it developed cold solder and will cause shifting related issues and codes.
Has anyone tried mounting the TCM to the brake lines to avoid overheating? Any suggestions on the padding to avoid causing short?
