more torque?
t bone
If i was lookin for more toque rather then HP, what mods should i be lookin into? Im just not happy with 1st and 2nd gear?
If you make more torque in 1st and 2nd you won't get traction.
But the best way to acheive what you want to get is to make the turbo system breathe easier with an intake, turbo inlet pipe, and downpipe. That will reduce spool time. You can also go with the Cobb Access Port...that gives a good amount more torque through the whole rev range. It also will get rid of the boost limit in 1st and 2nd (or at least raise it)
...You can also go with the Cobb Access Port...that gives a good amount more torque through the whole rev range. It also will get rid of the boost limit in 1st and 2nd (or at least raise it)
*sigh*...
Unless you have an 09, in which case they still havent gotten around to making it work with it.
doesn't mean they dont work, just means its not confirmed as of yet
No,....they dont,...there was a thread there with someone asking why the A/P wasnt working correctly with his 09,...Josh commented that the reason was because there are slight differences with the 09 software.
Havent people also been having problems with the ecu learning with the AP and not having consistent gains?
I guess so,....its a different ecu somehow,....dude on Cobbs forums had a 07, crashed it, got an 09 and the A/P refuses to load on the new one after he unmarried it from the old.
hahah(rlaugh)...that suck for you guys but get a standback everyone is selling ap because they are getting high knock
or get an 07-08.5
haha
no, im kidding. Standback is looking like the more reliable option for me anyway.
