more pictures
blackmica08
2008 mazdaspeed3
i took more pictures of the car now that the engine is out, as you can see there are 4 holes in the block instead of four as we initially thought. i dont know if you guys can see but the piston is still in there, only a small part of the piston broke loose. the tech is going to open the engine as soon as he is done assembling my car back, once its open i post more pictures, btw i while there i met jake with a white speed6, he is usually around these forums and ********** forum, also ms3 kendall showed up.
