Mods for auto 03 P5 ?
Just trying to help the guy out by offering him some new choices!! Apparently a turbo is the only way to go with these cars....:rolleyes:
You can spend 4gs on a NA setup and achieve around 150-160whp or you can buy a turbo and spend the rest on a new tranny after you blow it up or you can PM matty.
Brian MP5T said:
Lentech Tranny Mods...
MaM Sleeper Kit
AWR Mounts
Tein-SS
= $6K (shrug)
p.s. can anyone show me 1 person who's done any of the Lentech or Level10 automatic tranny mods for the protege?? I've never seen ANYONE do them.
Super Matty P said:
= $6K (shrug)
Well it's an auto and the turbo will kill it...
Lil Freek has one on the way....
Super Matty P said:
you're right a TURBO will kill it. I think you're missing my point.
So Your point was... (smash)
A. Don't turbo an ATX
B. Lentech is not a place to go
C. I cant read minds
D. All Of The Above...
Yo! I'm back. I thought about it some more and figure a good N/A set up just like mine but add lightweight seats, cf hood, and really light rims. I went with 17in rims and they weigh the same as stock, they look nicer and I have wider, stickier tread. I can't figure how to put a pic of my ride on my signature, I tried for about an hour last night. Anyway that setup will be reliable and look really hot with the seats and stuff. That's actually what my plan of attack is for my ride. I've got about 7 or 8k (cdn)to play with yet, so I'm actually laying low till spring and learning more about this import stuff! Anyhow, good luck and I will keep trying to post a pic of my ride! Don't forget to add to my rep!
go to upload pictures and upload the picture
copy the address for the picture to your profile and place the img code before and after..
Delete the "_" as I can''t type the code or the computer will try to load a picture.
[_i_m_g_] address [_/_i_m_g_]
turbo at 4-5psi. you'll kill all or most ricers, and it won't significantly damage the long term reliability of your engine. get a tranny cooler and temp gauge along with the standard turbo accesories and you should be golden.
yeah, turbo's often infect their owners with the "boost bug". You've gotta come up with someway to make it more difficult to increase the boost....like requiring some handtools and 30 minutes would be enough to make people think about what they're doing,.
Brian MP5T said:
Nobody stopps at 4 PSI...
Of course not :)
Boost = 4 PSI;
While (Engine != explode),
- "hmm, adding 0.1 PSI to it wouldn't hurt right?";
- Boost = Boost + 0.1 PSI;
end
Bank = Bank - $$$$$;
with that kind of money....just swap in the msp motor/tranny/ecu and then upgrade the turbo with either the hi-boost set up or one of MAM's kits.
Thats WAY redundant. If you were to go with a HiBoost kit you wouldn't need the msp engine or ecu....then only benefit would be the differential and axles.
i have a kit on ebay and i think your the man to buy it. If you do some valve bodies upgrade and some other s*** your auto could go a long way.
