Mods allowed for H Stock
Wanted to stay legal if I decided to do H Stock. Found some D-Force 15x6 wheels (11.8 lbs) at Phil's Tires (advertises racer stuff); Needs hub centric rings for sizing & spacers 5mm) for front for clearance. Using with 195x50 new Dunlop Direzzas. Just on this week. Will try out next weekend at Buttonwillow at least for road course use.
I don't think these wheels will work for H-Stock, stock is a 45 offset and the D-Force wheels are 35. Adding a 5mm spacer would make them 30 offset.
This is correct. There are some Miata wheels that came in 15x6 45mm offset. The expensive ones are highly saught after BBS at about 1000 for a complete clean set. They weigh around 12 lbs each. Spend some time on miata.net for more info. The other Miata wheels came on the STO I think and they are about 14.5 lbs each and go for 2-500 a set. The prices I listed are for clean wheels without curb rashes. YMMV.
