Saw this post on another forum...
interesting info: http://peswiki.com/index.php/Direct...a_Fuel_Additive
up to 35% increase reported. Acetone said to improve the fuel's ability to vaporize completely by eliminating the surface tension that causes an increase in particulate vaporization temperature. (PESN; March 18, 2005)
more info: http://www.lubedev.com/smartgas/faq.htm
even MORE info: http://pesn.com/2005/03/17/6900069_Acetone/
and an FAQ: http://peswiki.com/index.php/Direct...ne_Additive:FAQ
basically.. it helps break up the surface tension of gasoline and helps it vaporize easier. Add 1-3 ounces acetone per 10 gallons of gas. So is this all BS or does it really work?
http://www.lubedev.com/smartgas/additive.htm
