Mint SS V3 FTC Tunes
Deff subbin this one. I have mine set to guage pressure. Working out fine for me as well. The other way never got out of vaccum. Once i have mine dyno tuned i'll load up the map on here.
Well I was out tunin again tonight and I might have discovered why the map sucked for 25fconv...... I had a MASSIVE vacuum leak on the map sensor. The plastic cap on it was leaking all to hell. After I fixed that the air fuels were all ****** up. Super rich everywhere bogging out hardly drivable lol. Needless to say I have fixed it up and created a very conservative map that gets 11.3-11.5 across the board. I've also found a pretty good timing retard which feels really good.
max boost was at 8.5psi but the map works good for 6-10psi too
I replaced the one in the first post with the new one so feel free to try it out 25fconv!!
Tomorrow I'm going to work on a bit more aggressive tune with high 11s low 12s and I'll post that too.
Car feels AMAZING now, can believe I had a vacuum leak like that i feel dumb lol.
settings = gauge pressure, programmable signal calibrator
Alright I will give it a shot tomorrow and see what happens. I will keep you posted and let you know.
You need an OBD2 Scan tool with data read out to log the actual timing advance.
Finally got a chance to see the timing advance, at idle its weird it goes from 8.5* and drops to 1.4* and keeps doing that....I haven't gotten to drive around and see where the timing advance goes from there......if there is an issue can it be remedied some how?
