Millenia Super Charger Pictures
swamper8
Greetings all,
Does anyone have pictures of a millenia engine with and without the supercharger installed? I purchased a used millenia supercharger with the intent of retrofiting it to a different vehicle. I have been trying to figure out where to get the oil feed/return lines but my research seems to point to the supercharger bolting very close/directly to the block? I have found references to a cooling plate which goes on the bottom of the supercharger, but I don't know if there's lines that attach to that or if this plate is sandwiched between the supercharger and the block? Some install/removal pictures would be helpful if anyone has them.
Thank you
I pulled one from the local junk yard. It sits in the V and bolts straight to the engine. From what I have read it is internally oiled. What are you planning on putting it on? If you come up with any good info on the supercharger let me know. I'd like to use mine for a project one day too so the more info the better.
The oil feed comes through the base of the supercharger where is sits against the engine from what I remember. I replaced one years ago, lots of fun there.
Derrick
