I wanted to ask if anyone is running E85 with thier MicroTech?
I have a question. Does anyone know if there would be an issue with connecting both main and A/C fan relays to the microtech so that both fans are controlled by the standalone?
My car is very difficult to start, and idles very rich. Well it did back when there wasn't a hole in the block.
Anyone? Just having a hard time starting. But once it's running everything seem good. What should I be adjusting to help start up?
I also have a rich(10.4) idle afr
What injectors?
I brought mine to a Microtech tuner, and he coldn't even get mine to start or idle like a stock car. for some reason the change in cll values either makes it off the scale lean, or far too rich, and there seems to be no middle ground.It cranks but doesn't catch. Tried pulling the plugs and only one plug seems to be firing on start. Reason I know is because I put new plugs in and only cylinder 2 plug is dirty. I've killed the battery at one point trying to get it started. Thing is when it does catch it sputters for about 3-5sec then dies. But if I keep at it and it does idle it idles fine just really rich. I've never used a system so in depth and don't even know where to start when it comes to changing values.
^thanks
I'm still having a hard time during cold starts. When the car isn't cold it starts pretty easily. Another issue I'm having us stalling when releasing the throttle. My idle is pretty high at 1100-1200rpm. Also idle afr is pegged at 10.0
And what's the thing with adjusting the brass screw? Instructions say unscrew it till it feels easier to turn. Then turn it back in one full turn. Could that have something to do with me stalling when releasing the throttle. The only other way for me to counter the stall is either throttle while braking to keep the rpm up then slowly let it drop. Or raise my idle via the 8mm bolt and hex screw to an unwanted 1500rpm.
Advise please. Thank you
