Blindeye_03 said:I got the engine runningbut its VERY rough...gotta set the idle tomorrow along w/ the timing...will post back tomorrow
-justin
The idle shouldn't cause it to run rough unless it's set waaay low.
Here are a few things to check:
-Check for vacuum leaks and make sure all of your injectors/spark plugs are firing. Pull each plug one by one and inspect it. Are you using new plugs? If new, and one looks like it did when it came out of the box, there's no fuel. If it's wet, there's no spark.
-Make sure your VAM is connected (I've made that mistake before).
-Check your timing with a timing light (the CAS may be misoriented).
-Confirm the proper order of your plug wires on the coil pack.
