Miata drain tubes/sloshing sound
Jeezus
2002 Mazda Protege, 2002 Mazda Miata, 1982 Mazda RX7
Hey guys, did a search but only found info for NA miata's, not NB's.
I have a 2002 Miata that has sloshing sounds from the passenger rear. Filled the tank up and it is still there. I put the spare on the car and jacked up the rear end and can get little drops of water to come out.
My question, where are the drain plugs on the car? And where could the clog come from? I would assume from a clogged drain tube from the convertable top, or maybe cracked with age?
Please help! Thanks!
Found/Fixed the problem, you can delete the thread.
Similar Threads and Articles
