Mazdaspeed6 won't move...Help
Replaced the Tc, drive car, worked fine, heard some grinding, stopped car. Had to start car in first as would not go into gear with pushing the clutch, it would grind. Got home, car sat, next day worked fine, went for drive, took off from stop sign, heard a little grinding, now no power to wheels, can shift through all gears without pushing clutch while it is running. All arms on trans move when shifting though gears, clutch pedal has full movement, and feels fine. Wheels spin opposite direction on jack stands, in gear and not in gear. They spin in gear with clutch pedal released. Clutch was working great with no issues
