Koenig
No it's Brandon, Just to the East of Tampa.
Ft Lauderdale is a fair drive away, I'll just go ahead with it.
The reason why I said if it ain't broke is because, I don't want to have to go through all that dropping of the engine and disconnection of coolant hoses etc.
The Service areas up here haven't been the best and this is the second one I've been too.
The first one I used to go to in Brandon (15 mins from the house) took 3 hrs to remove a screw in the tire
I had already jacked the car up and removed the wheel and was ready to take it up there and they said they have to see the whole car (WTF) it's a stock Speed 6 rim with the Original Bridgestone Potenza tire on it, my info is in the computer.
So I then had to install the fricking May pop (Donut) and then after the 3 hrs wait to fix it, and the fact that they had marked the rim (gouged the Paint) and were going to put the clip on/hammer on weights I was pissed,
the Service guy was lsaying "but you have to have weights on the wheel to balance them", I Said "I know that, I want the stick on weights", he said "but they come off all the time" I said no they don't actually, I am a bridge inspector so I am out on the roads all the time and I always see the clip on weights all over the place.
I have yet to see a stick on weight laying in the road, the centrifigal force helps to force the weight to the rim.
Service guy was like oh yeah that makes sense.
So there is the customer trust issue.
Sorry here we go a long rant
There was another small problem I had I while back which was the reason why I stopped going to the one in Brandon.
The Intercooler Cowling/cover has a clip on the back of the cover, two bolts to secure the cover to the intercooler mounted on the front, well one had sheared off and the remaining thread was still in the intercooler, after a half hour trying to explain to this one chick service advisor about the bolt she was none the wiser (her answer was that car has an intercooler, now banging head) I said listen I will be there in 10 mins,  can I just pick up a new bolt. Well we need to see the car to do warranty work yada yada. Ok I'll be there in 10 mins.
I get there and show this woman where the bolt was located, she said I'm sorry you'll have to book it in for a new nut, "NUT" it is a sheared frickin Bolt, I want a new bolt, after 15 mins of trying to explain I was like screw it.
and I had vowed never to take my car to them again as it was, as my usual Service is across Town in Tampa.
I then got in touch with another dealer / service across town in Tampa.
I spoke with the service manager there and he knew exactly what I was talking about.
So now it is a 45 min drive to go over there and he said you'll have to leave the car with us, it'll be done by this afternoon, so I get a rental out it yippie.
anyway I get the car back later that day and check their work, the bolt they replaced was cross threaded (WTF) I managed to finally get it out and remove the cover, they only slipped with the drill trying to remove the old threads and drilled a completely new hole into the aluminum of the intercooler, and they didn't even tap new threads, they relied upon the new bolt cutting it's own threads. (argh) idiots.
I should have got the part number and ordered the new bolt and then did the work myself and this is two completely separate services. they screwed up something as small as this, what are they going to be like with a big job.
Sorry for the rant but as you can see I am stuck between a rock and a hard place, I don't trust any of them to perform the work competently, which is why I am a little concerned, I don't want to have parts falling off later, or the car breaking down
I'll keep you all posted, hopefully it won't be this long next time.
