I was just thinking about my springs actually. The Cobb that are currently on the car. I have coilovers in the kitchen but that is another story. What i was thinking was, the rear springs have finally settled after about ten thousand miles. The car is level again.
I have the Hotckis sways and the rear is set on the stiffer setting. I have had it aligned and it fell within specs with these parts in place.
These have not caused the struts to fail but they are on the edge of being overburdened. The car sets very well now in the turns. If you are looking to get some rotation out of the car install JUST the rear sway bar. The rear will come around nicely if you like that stuff. In my humbled opinion, the tires were the best upgrade to performance driving. A little wider and alot stickier. If you are autocrossing the front could use more negative camber in front and the rears are fine within stock specs with my car and the. I hope i have not confused the issue. I do not belong to SCCA so i do not know the class regulations but the sticky tires and bars and just springs have improved my car considerably in turning and braking. Does that help?
