Hi from Ukraine
Engine:
- Sleeve block
- Connecting Rods Carrillo Pro-SA-beam
- Pistons CP-E Wiseco MagnumDI ™ Stage2
- Turbine Garrett GTX 3076r 0.82 TiAL
- Exhaust manifold CP-E
- Wastegate Tial MV-R 44mm
- Custom DP 76 mm
- Custom KB 76 mm
- Vlow off Turbosmart Dual Port ********** Black Out Edition
Compact
- CX Racing front mount intercooler
- Inlet Pipe CP-E Nviscid
- Intake ATP Turbo 3 "MAF Housing
- Nulevik AEM DryFlow air filter
- Cylinder head gasket Cometic 1.3 mm
- ARP cylinder head studs
- Fuel injection pump (pump) KMD Tuning V2.1 Fuel Pump Kit w / Armoloy Coating
- Spark plugs NGK Laser Iridium ILTR6A-8G
- Snow Performance methanol injection
- Header Wrap DEI
- The hood to the turbine Turbo Insulation cover shield
Transmission:
- Rear engine bracket Mazda Garage
- Right and front engine mounts Mazda Garage
- Front and rear bearing gearbox Mazda Garage
- Clutch kit organic ACT ProLite
- Reinforced hose coupling Techna-Fit
- Rear left axle DSS
- Shift knob TWM Stage 2
- Short-scenes adapter CAT James Barone Racing
- One-piece aluminum backing gearshift
Suspension:
- Shock absorbers Bilstein B6 HD
- Springs Ebach Pro-Kit - 30mm
- Front strut Mazda Garage
Brakes:
- Brembo 4x 350x32 mm
- Drives the front wheels StopTech Slotted
- Brake pads EBC Red Staff
- Reinforced Hoses Techna-Fit
- Brake fluid Motul RBF660
Electronics:
- The boost pressure sensor Shadow
- Sensor EGT Shadow
- Launch-kontrol/flat-foot-shift VersaTuner
- Computer MSD Dashhawk OBDII logger
- Turbo Garage MAF Emulator 3 Boost Control
- Bosch 4 bar MAP sensor
- 3x port solenoid Grimm Speed (MAK)
- Chip VersaTuner
- Apexi turbo timer
Wheels:
- Enkei Evo X 8.5 x 18 ET 38
- Summer Nitto Invo 225/45 R18
- Winter Pirelli Sottozero Winter 235/40 R18
Оils :
Redline 5w40 motor oil
Redline MT-85 oil in the gearbox
Redline LSP oil in the gearbox and razdatke
Redline WaterWetter additive in antifreeze
Exterior:
- Lip on the front bumper EZ Lip
- Rear lights LED Ring Tails
- Lenses Bi-Xenon
- Shortened antenna CX 7
- Visor on the rear window
- On windows EGR
Engine:
- Sleeve block
- Custom DP 76 mm
- Custom KB 76 mm
Compact
- Header Wrap DEI
Transmission:
Suspension:
Brakes:
Electronics:
- Sensor EGT Shadow
- Chip VersaTuner
- Apexi turbo timer
Wheels:
Оils :
Exterior:
- Lenses Bi-Xenon
- On windows EGR
