Mazdaspeed 6 Darth Vader
DimaDeka
Mazdaspeed 6 / MPS 6
Hi from Ukraine
Engine:
- Sleeve block
- Connecting Rods Carrillo Pro-SA-beam
- Pistons CP-E Wiseco MagnumDI ™ Stage2
- Turbine Garrett GTX 3076r 0.82 TiAL
- Exhaust manifold CP-E
- Wastegate Tial MV-R 44mm
- Custom DP 76 mm
- Custom KB 76 mm
- Vlow off Turbosmart Dual Port ********** Black Out Edition
Compact
- CX Racing front mount intercooler
- Inlet Pipe CP-E Nviscid
- Intake ATP Turbo 3 "MAF Housing
- Nulevik AEM DryFlow air filter
- Cylinder head gasket Cometic 1.3 mm
- ARP cylinder head studs
- Fuel injection pump (pump) KMD Tuning V2.1 Fuel Pump Kit w / Armoloy Coating
- Spark plugs NGK Laser Iridium ILTR6A-8G
- Snow Performance methanol injection
- Header Wrap DEI
- The hood to the turbine Turbo Insulation cover shield
Transmission:
- Rear engine bracket Mazda Garage
- Right and front engine mounts Mazda Garage
- Front and rear bearing gearbox Mazda Garage
- Clutch kit organic ACT ProLite
- Reinforced hose coupling Techna-Fit
- Rear left axle DSS
- Shift knob TWM Stage 2
- Short-scenes adapter CAT James Barone Racing
- One-piece aluminum backing gearshift
Suspension:
- Shock absorbers Bilstein B6 HD
- Springs Ebach Pro-Kit - 30mm
- Front strut Mazda Garage
Brakes:
- Brembo 4x 350x32 mm
- Drives the front wheels StopTech Slotted
- Brake pads EBC Red Staff
- Reinforced Hoses Techna-Fit
- Brake fluid Motul RBF660
Electronics:
- The boost pressure sensor Shadow
- Sensor EGT Shadow
- Launch-kontrol/flat-foot-shift VersaTuner
- Computer MSD Dashhawk OBDII logger
- Turbo Garage MAF Emulator 3 Boost Control
- Bosch 4 bar MAP sensor
- 3x port solenoid Grimm Speed ​​(MAK)
- Chip VersaTuner
- Apexi turbo timer
Wheels:
- Enkei Evo X 8.5 x 18 ET 38
- Summer Nitto Invo 225/45 R18
- Winter Pirelli Sottozero Winter 235/40 R18
Оils :
Redline 5w40 motor oil
Redline MT-85 oil in the gearbox
Redline LSP oil in the gearbox and razdatke
Redline WaterWetter additive in antifreeze
Exterior:
- Lip on the front bumper EZ Lip
- Rear lights LED Ring Tails
- Lenses Bi-Xenon
- Shortened antenna CX 7
- Visor on the rear window
- On windows EGR
holy balls, you make some power on that thing... How has no one commented on the HP that monster is making, JEEZ!
that is some sick tune man, well done.
is mazda garage some place overseas or do they have a website. Im interested in that front upper strut bar and the price tag that might be on it.
Crazy ukis! Clean car. Very nice.
Although I am curious what you do to be able to afford that thing. :)
You are running almost similar turbo kit setup that i will soon have :) Im getting the CP-E Atmosphere kit with GT3076 :) Still on stock block though... :/
What you have done is what my goal is/would be if i could spend that much money on the block :)
