Mazda's new engine boosts fuel efficiency by 30%
So if increasing compression makes for more power why did Mazda reduce the compression ratio for the diesel?
Although they did increase the ratio for the petrol. Can someone explain.
I'll try.
Lowering the compression ratio on the diesel allowed them to make the engine lighter, produce less NOX emissions (no urea after-treatment) and it allowed for a higher readline.
It also allows for more fuel to burn closer to the top of the cylinder stroke, improving the amount of work done by the fuel.
http://www.mazda.com/en/innovation/technology/skyactiv/skyactiv-d/
The power improvement for compression increase also isn't nearly as much as CX-sum wrote.
Going from 17:1 to 14:1 you'll only see a ~4% drop in power. Not hard to make up for that with more boost.
You might see a 4% increase in power for 1 point compression increase when you step up from 7.0:1 to 8:1 in a turbo engine, but once you hit higher compression ratios the increase gets lower.
Here's one reason for the reduced compression. "20 percent better fuel efficiency thanks to the low compression ratio of 14.0:1"
Plus there's this "Optimization of Combustion Timing by Lowering Compression Ratio
When the compression ratio is lowered, compression temperature and pressure at TDC decrease. Consequently, ignition takes longer even when fuel is injected near TDC, enabling better mixture of air and fuel. This alleviates the formation of NOx and soot because the combustion becomes more uniform without localized high-temperature areas and oxygen insufficiencies. Furthermore, injection and combustion close to TDC result in a highly-efficient diesel engine, in which a larger amount of actual work (or, a higher expansion ratio) is obtained than in a high-compression-ratio diesel engine(Fig.2)."
That said Mazda was probably okay with balancing out some HP for increased MPG and maybe better emissions as per above? I mean that engine already has ample TQ.
A big factor is the turbo on the diesel. When the piston is down it crams more air in raising the effective compression ratio. Example, in a 15 psi normal air pressure environment if the turbo is at 5 psi, you raised the effective compression ratio by 1/3, from say 15 to 20.
Yep. Static compression ratio is not the same as dynamic.
