Mazdaformance Protege Turbo Finally Dyno'd
Chojin
Hey Everyone,
Well, we've finally put our protege on the dyno. This was a long time coming, but we had to work out a few bugs before we felt comfortable putting it on the dyno. By the way, all numbers are SAE Corrected.
First, a little background info. on the car's motor/tranny/turbo setup:
- 2002 Protege ES 2.0L, 5 spd.:
- Stock Engine
- ACT HD/SS clutch
- Fidanza flywheel
- Quaife LSD
- Custom 2.5" exhaust system
- Custom Turbo Setup:
- Kiwi Fabrications SS manifold
- Garrett T28 Ball Bearing turbo
- Custom 2.5" down pipe
- Tial Sport wastegate
- HKS intercooler
- Tial Sport BOV
- Custom intercooler piping
- HKS air filter
- Apex-i AVC-R boost controller
- Fuel Management Setup:
- RC 370 cc/min injectors
- Vortec 6:1 FMU
- Split Second Programmable Signal Calibrator w/R4 software
(Modifies MAF signal to fine tune the fuel system via a laptop)
Dec. 27, 2002:
On our first run for the day, we put out 160.9 WHP and 173.8 WTQ at 6.5 psi. We were a little disappointed, but then we looked at the A/F graph and were like whoa, it's lean at the lower rpms and then very rich up top (darn Vortec FMU).
On our last run for the day, we put down 177.9 WHP and 182.6 WTQ at 6.5 psi with just tuning the A/F ratio from 4500 rpm to redline. Not exactly what we were hoping for, but we couldn't tune the lower rpms without throwing a check engine light.
We talked with some the guys at Mazda's Mazdaspeed Division regarding the inability to tune the lower rpms without throwing a check engine light. They told us that we could not make any changes to the A/F ratio below 4500 rpms because the stock ECU stays in closed loop operation until that point, even though the car is at WOT.
So basically, our Vortec FMU is fighting the stock ECU below 4500 rpms. The FMU wants to keep more fuel in the rail to feed the injectors, but the ECU prevents the injectors from spraying since it wants to see a 14.7 A/F until 4500 rpms (at which point it goes from closed loop mode to open loop mode). Our fuel guage goes crazy from 2500 to 4500 rpms and then steadies out until redline.
We are working with a company to solve this problem by hacking the stock ECU to get it into open loop at WOT at any rpm, which will let us continue using the Split Second PSC. If this doesn't go through, we'll have to use a stand alone setup. So, hopefully the MicroTech setup Terry is working on will solve this problem.
After talking with the Mazdaspeed Division guys again, we decided to up the boost. They said that even though the A/F below 4500 rpms is un-tunable for now, the potential for damaging the motor in that rpm range is slim for the boost we want. Though they did advise not to go past 9 psi or we'll have to find a way to retard the timing.
Jan. 10, 2003:
On our first run for the day, we put down exactly the same numbers as our last run on Dec. 27 still at 6.5 psi (same exact weather conditions).
On our last run for the day, we laid down 200.7 WHP and 200.3 WTQ at 8.5 psi and maintained an A/F of approx. 12.1:1 from 4500 rpms to redline. We were fairly pleased with these numbers (100 WHP more than the stock WHP).
Once we get the lower rpm tuning problem solved, the entire HP and TQ graph will be raised up. Until then, there is not much more we can do to increase the power without going to a stand alone engine management system. Hopefully we can get 220 WHP with the hacked stock ECU and the Split Second PSC.
Also, the Mazdaspeed Division guys said that the stock rods are good to 225 WHP before they bend, just an FYI.
Cheers,
-Shawn
is this a turbo kit that is being put together and in the testing forum....soon to be released once all of the kinks are worked out?...those are some impressive numbers...and I am interested in the future production of this set-up
Here are a few courtesy shots of the Mazdaformance test mule. :D
Ooops, I forgot that you can't link from car and model.
Their car has a very nice manifold. Have you guys run into any problems with the SUS. I've heard mixed opinions on cast and SUS manifolds. I'm more partial to the SUS for the bling factor of it.
225 HP and the rods will bend. Hmmm...that's interesting. I hope to upgrade my exhaust, and then go from 6 to 8 PSI within the month. If all goes well, I will be up there with ya killing everything! (almost):D This is great news Chojin! (thumb)
Here are the pics again....
Sorry about not delivering the first time on the pics, but here you go.
Check out the link in my sig for more pictures of their Protege.
Nice setup and nice numbers, (the volks are dope) we were initially looking into using the split second unit. We currently use there a/f meters and they are awesome. I spoke to some mazda guys and they said the motor is good for 250 hp with proper fuel ect....hmm interesting info. The ecu we will be pushing for 250 whp with 10 psi.....if this is attainable...we will see.
How do you like the tial bov? They are beautiful units annd how is the lsd?
Off topic, but those wheels are awesome and exactly like what I would like someday for my car. I assume they are Volks? Probably expensive? Anything out there that looks the same but cheaper? :D.
Chris
Nothing looks the same if it's cheaper. lol. Ya those wheels look familiar, even on black but I got the P5.
Nicely done,
Rishie
Chris
i think Konig Rated Rs are similar.....powdercoat em to your heart's desire
falkofire - We do plan to make a kit based on this prototype. There will be some revisions to the prototype before we decide on a final setup to produce a kit from.
APEXistud - We have not ran into any problems with our manifold. Kiwi Fabrications does extremely high quality work, and I do not forsee any future problems with this manifold. That being said, I do not see this manifold making it into the final production kit due to its high cost. We are looking making a high quality cast manifold based on this design, but need to do some more cost analysis.
chdesign - Here are a few recent pictures of the car, no engine shots though.
AutoXer - Here are the dyno sheets. The first one compares Run 1 and Run 15. The second one compares Run 15 and Run 26 (our last run).
slug420 - A T25 boosting the same level as a T28 will make less power (with everything else being equal - car, engine, etc.). The ball-bearing unit we use achieves 6.5 lbs of boost at 2500 rpms and 8.5 lbs of boost by 2800 rpms. Simply awesome.
spoolinmp3 - The Tial BOV is very nice. We did have to increase its spring pressure though, to keep the car running properly. The valve would open ever so slightly, causing eradic idling, dying while coming to a stop with the clutch in, etc. Once we shimmed the spring and adjusted the idle screw, all the problems went away. The Quaife LSD is just awesome. Grip, grip, grip, and more grip is how I would best explain it.
DooMer_MP3 - I know Rota has a wheel that looks almost exactly the same, but I'm not sure if you can get it here in the states.
Cheers,
-Shawn
Hey Shawn, I was wondering what happend to the "MP3-T". I haven't heard or seen the car since the Dallas HIN. My motor is toast. I ran over some road debris and the oil line got knocked off. So now my rod bearings are like chewed up rocks in there. I'm glad to see you guys progressing with the car though. You are the only competition for Terry's kit so far in the power dept.
Oh yeah, if all you guys are impressed with the power and the way it looks, Ask Shawn how much money they have put into the "MP3-T". As of the Dallas HIN last summer, tha number was around $30,000!(omg) You guys are doing to some good R&D though.
Blu,
Thanks, but I think the picture on his website demonstrating SPOOL lowering springs is his car, and therefore aren't the same wheels :D.
Chris
big_ben - Terry's kit made almost the same power as ours did, but at only 6 psi. That is impressive. Imagine how much power he would make at 8 psi with the proper tuning, whoa.
Our T28 ball-bearing unit is smaller than their unit, hence the similar power numbers at the different boost levels.
Cheers.
-Shawn
