Mazda6 Oil light flickering/and radiator fan always on
zizaspeed
2008 CX-9 AWD
2008 Mazdaspeed3
So since I picked the mazda6 v6 I have noticed the radiator fan always on when car is running continue to stays on up until about a minute after the car is off. I've done some searching but haven't really found a solid answer and am hoping someone has had the same problem and a solution. Another more recent concern has been the oil light that pops up sometimes when I come to stop or when i turn the car on, but once I start driving it is gone and Oil level is normal. I'm thinking maybe it's the senor going bad or maybe loose? Any help would be appreciated. Thanks.
What year is the vehical? Sounds like first problem is your relay, or fuse is shot. Check all the fans, radaitor fluid is clean an proper level cause can be clogging internal giving wrong reading, discount the power clip on both of the fans, make sure no build up is on them. For the oil thing defently sounds like a sensor issue, use a obdi 2 tester, (one of the dianoistic tools that go into ecu). I need more info on maintence, year, an mileage.
04 6s with bout 134000 on the clock. I actually just did. Coolant flush when changing my thermostat and noticed it doesn't stay on when the car is off now but still turns on instantly when key is in ignition
