papason100
How do u remove the headunit of a 2005 mazda6?
I too am trying to remove the center console on my 2005 Mazda6. I'm following the directions over here. I got the 3 screws that are holding the console in removed (the 2 below and 1 in the glove box). I can't seem to get the console out though. I've exerted quite a bit of force but the bottom of the front panel just bends forward. I'm afraid that if I bend it any further it will break. Am I missing something or is it supposed to bend forward really far. If so, i've given it all my strength and the damn thing won't come off.
I too have an automatic. After I got the cupholder out the plastic piece around the gear shifter almost fell off. If yours doesn't I would wiggle it a bit and see if you can get it out that way. It doesn't have any screws holding it on. It should just snap off. One thing you do need to do though, make sure that you have your parking brake on and put the car in neutral. I had to move it between neutral and reverse in able to slide the plastic piece all of the way over the gear shift rod.
