Mazda5 Maintenance and Quick Reference Spec Sheet
2008 Mazda5 GT
I have always made a cheat sheet with specs for quick reference. It would include fluid levels, bulb types, torque specs for common/critical components. I would get these from a Hayes manual but since I don't have one for the Mz5, I wanted to see if folks here would like to contribute (questions and answers) to building this. The idea is to have his fit on one printable page so you don't have to flip through any book to find it and can be easily disposed of/printed. Following manufacturer specs!
Applicable for 2006-2010.
::Fluids::
Note: when draining oils, a small 0.x quantity will remain coating parts and/or in crevasses! Values below are for a dry system.
Motor oil capacity (new filter): 4.5 US qt.
Motor oil capacity (reusing old filter): 4.1 US qt.
Motor oil weight: 5W20 (2006-2010)
ATX fluid capacity: 7.8 US Qt.
ATX transmission oil weight: Mazda M-V (# 0000-77-112E-01) / Ford Motorcraft FRN5 (# XT-9-QMM5). Do NOT use Mercon V
MTX fluid capacity: 3.3 US Qt.
MTX transmission oil weight: 75W90
Coolant capacity: 1 gallon
Coolant type: FL22
Brake fluid type: Dot 3
Clutch fluid type: Dot 3
Power steering fluid type: Mercon V
Etc...
::Toque/pressure specs::
Engine drain plug: 22-30 ft/lbs
Oil filter housing: ~22 ft/lbs
Oil filter drain plug 6mm: ~7.6 ft/lbs
Caliper mounting bracket front: 57-75 ft lbs
Caliper mounting bracket rear: 44-56 ft lbs
Caliper slider pins (F/R): 19-22 ft/lbs
Lug nuts: 65-86 ft/lbs
Tire pressure: 32 PSI
Etc...
::Bulb::
Low beam halogen: H7
Low beam HID: D2S
High beam: 9005
Fog light: H11
Parking light: 1157
Turn/flasher: 1157
Back-up/Reverse: 921
Stop/Brake light: 7443
Fender marker light: Non serviceable! Replace.
License plate: 2825
Dome light: DE3175
Etc...
::Fitment/Size::
Lugnut size: 21mm
Lugnut thread size: 12x1.5mm
Rim bolt pattern: 5x114.3mm
Rim offset: +52.5mm
Rim bore: 67.1mm
Caliper mounting bolt size: 17mm
Slide pin bolt size: 7mm allen
Oil drain plug size: 17mm
Oil drain plug thread size: ??
Oil filter (canister) thread size: 3/4 16
Oil filter (cartridge) drain bolt: 6mm allen
Oil filter (cartridge and canister?) housing: 76mm cap type oil filter wrench (14 flute)
Wiper Front Left: 26" length x 8mm (5/16") wide
Wiper Front Right: 16" length x 6mm (1/4") wide
Wiper Rear: 12" length x ?mm (?) wide
http://www.motortrend.com/roadtests/minivans-vans/112_0809_2008_mazda5_first_look/viewall.html
Base Price $17,995-$22,515
Vehicle layout Front engine, FWD, 5-7-pass, 4-door Mini-van
Engine 2.3L/153-hp/148-lb-ft DOHC 16-valve I-4
Transmission 5-speed manual; 5-speed automatic
Curb weight (dist f/r) 3417-3475 (mfr)
Wheelbase 108.3 in Length x width x height 181.5 x 69.1 x 64.2 in
Headroom, f/m/r 40.7/39.4/37.1 in
Legroom, f/m/r 40.7/35.2/30.7 in
Shoulder room, f/m/r 55.5/55.6/49.2 in
Cargo volume 70.9 cu ft
Weight dist., f/r 56/44 manual, 57/43 automatic
EPA City/Hwy Econ 21-22/27-28 mpg
CO2 Emissions 0.80-0.83 lb/mile
http://www.modifiedlife.com/2010-mazda-5-car-radio-wire-information/
AUDIO:
2010 Mazda 5 Car Radio Wire Information
Car Radio Battery Constant 12V+ Wire: Blue/Red
Car Radio Accessory Switched 12V+ Wire: Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Green/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 1″ Tweeters
Car Audio Front Tweeter Depth: 1″
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Red
Left Front Speaker Negative Wire (-): White
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Yellow
Car Audio Front Speakers Size: 6″ x 8″ Speakers
Car Audio Front Speakers Depth: 5″
Car Audio Front Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Violet
Left Rear Speaker Negative Wire (-): Pink
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Black/Blue
Car Audio Rear Speakers Size: 6″ x 8″ Speakers
Car Audio Rear Speakers Depth: 5″
I say we make this a group exercise. :)
::Fluids::
Motor oil capacity (old filter/new filter):
ATX fluid capacity:
Coolant capacity:
Brake fluid type:
Etc...
Engine drain plug:
Caliper mounting bolt:
Lug nuts:
Etc...
::Bulb::
Low beam: H7 (2006-2010 Sport, Touring, GS, GT), H11? (2012+ Sport, Touring, GS), D2S (2006+ Grand Touring, 2012+ GT)
High beam:
Flashers:
License plate:
Brake light:
Dome light:
Etc...
Thanks Dkaz. That was the idea, to see if we can get some team play here but it seems we have a lot of passerbys and not many willing/able to contribute. This print out will be useful if something breaks on you while you are on the road and you need to find something for a quick fix. Most answers can be found with key word+mazda3 but that is not so easy if you are on the road.
Some additional items.
::Fitment::
Rim bolt pattern:
Rim offset:
Rim bore:
Oil drain plug thread/pitch:
Oil filter thread/pitch:
::Fitment::
Rim offset: +52.5mm
Rim bore: 67.1mm
Just because I know those off the top of my head...
Honestly though, it's easier to just pull them all from the service manual.
Agreed. We are all masters of the infoweb when we are connected. A cheat sheet has come in handy for me many times, which is why I take the time to make one, even though I have my smartphone, as nothing beats a hard copy with info right there. Also, come change interval I know the processes but always forget size/capacity/etc. needed, but maybe this is just me.
Benefits:
It is much quicker to get instant access to data, especially if you are on the road.
I hate having to stop to flip thru a book or having to ‘search’ sepcs when I am in the middle of doing something, especially if my hands are dirty. I want it now :D!
I'm not promoting that everyone do this. Just wanting to share how this has become a handy tool for me, which is why I take the effort to compile this info for my cars. Shrink it down into half a page, print it, and insert into glove box. I would organize it a bit in Excel to make it easier to read.
So, anyone able to help fill in the missing blanks or confirm if something is totally wrong?
::Fluids::
Note: when draining oils, a small 0.x quantity still exist coating parts and/or in crevasse! Values below are for a dry system.
ATX transmission oil weight: Mazda M-V / FRN5 (NOT Mercon V)
Coolant type: FL22
Etc...
Caliper mounting bolt: 79-83 ft/lbs
Caliper slider pins: 19-22 ft/lbs
Etc...
::Bulb::
Low beam HID: D2S
High beam: 9005
Fog light: H11
Parking light: 1157
Turn/flasher: 1157
Side marker: ??
License plate: 2825
Dome light: DE3175
Etc...
::Fitment/Size::
Lugnut size: 21mm
Rim offset: +52.5mm
Rim bore: 67.1mm
Caliper mounting bolt size: ??
Slide pin bolt size: ??
Oil filter (cartridge) drain bolt: 6mm hex
Wiper Front (L/R): ??
Wiper Rear: ??
Interesting, I was just looking in the 2010 Owner's Manual this morning for similar information and wished for a "cheat sheet."
Motor oil capacity (old filter/new filter): 3.9 L (4.1 US qt, 3.4 Imp qt) / 4.3 L (4.5 US qt, 3.8 Imp qt)
Wiper Front (L/R): 26"/16"
Motor oil capacity (old filter/new filter): 4.3 L (4.5 US qt, 3.8 Imp qt) / 3.9 L (4.1 US qt, 3.4 Imp qt)
Thanks for the input.
