- 2008 Mazda5 GT
The recent cold weather really brings out the worst in my battery.  My ’08 is still on original battery so is due for a change.  I typically stick with DieHard (Sears) or EverStart (Walmart) but it’s been a LONG time since I looked into batteries so don’t know if quality or tiers have changed.  The specs for both look similar BUT the DieHard has a RC, which is a nice to have but the EverStart has a heck fo a warranty program.
I believe our cars use group 35. Anyone used a bigger battery that fits? I’m open to that as well. Appreciate any affordable yet good (asking too much?) battery recommendations!
EverStart MAXX-35 $110
Most powerful EverStart available
Starting power meets or exceeds manufacturer's specifications
Great for all-weather climates
North 640 Cold Cranking Amps /South 550 Cold cranking Amps
5 Year Warranty Program (3 Years Free Replacement + 2 Years Pro Rated)
Shipping Weight (in pounds): 37.6
Product in Inches (L x W x H): 9.6875 x 6.875 x 8.875
DieHard Gold 35 $130
Group Size: 35
Height (in.): 8.9
Length (in.): 9.8
Item Weight (lbs.): 33.5
Power Ratings:
Cold Cranking Amps (CCA at 0 deg.F): 640
Reserve Capacity (RC): 95
Design & Construction:
Battery Design: Lead-Acid
Battery Grade: DieHard Gold
Maintenance: Maintenance Free
Positive Terminal Side: Right
Temperate Zone: North
Terminal Post Location: Top
Warranties & Coverage:
Free Replacement Warranty Term: 36 months
Also, how much are stock batteries? Considering mine has lasted 6 years, it migth be worth it?.
Group Size: 35
Height (in.): 8.9
Length (in.): 9.8
Power Ratings:
 .  You could also do an upside down bolt with one nut against the bracket but the base of a bolt is not wide enough for my liking but more than enough to keep it steady.
