Mazda Oil Filter Question
My thoughts are first, the oil filter is tiny. My Goldwing motorcycle has a bigger filter. Denso is the oem for mazda and Toyota. I’m always going to use a Mazda filter. Why? Because it’s guaranteed to have the flow potential that my skyactive turbo engine requires. I do my own oil changes, I discovered the dealer had installed the value line filter when I bought the car. If you have the dealership doing your oil changes, you are probably getting the value line filter, it will have a MV at the end of the part number on your invoice. To me, the regular factory installed filter is usually just a few bucks more, even cheaper on line. It’s a $40,000 car. I see a few comments about the oil change interval, pointing out how modern synthetic oil will last through the long OE recommend interval. The reason to change the oil more often, in my case every 3,500 miles, is not because the oil doesn’t have the potential to go 7,000 miles. It does.
The reason I recommend more frequent oil changes to my customers with mazda skyactive engines is the incredible compression ratio those clever engines can achieve. In the NA, up to 14.5 to 1, 13.5 in the US, and 10.5 in the turbo. With those values, (used to be found in racing engines only) the engine is going to experience some significant blow by and windage. If you have seen one idle with the oil cap loose for a moment, that cap will dance from the windage. What that means to the oil is fuel contamination. Sure, you can have your oil analyzed, or just take a whiff off the dipstick.🤣 By about 3,500 miles I can smell fuel. I use what I believe is a very good quality oil, pennzoil ultra. Great as it is, fuel will break it down.
It’s just my opinion, but that’s the reason I don’t go 5,000 or 7,000 miles oil change intervals. I’ve taken a look at filters, like wix xp. It would probably filter better than the denso made OE, but Im not sure about flow specs and every aftermarket filter for our application has a adbv, the OE doesn’t. Mazda sure keeps it’s specs on bypass range hidden, I can’t find a spec on that either.
I believe I've read it is similar to the Subaru oil filter, with a higher bypass pressure relief valve. Operation of the engine with a lower pressure valve might let unfiltered oil through.
Interesting conversation with the parts guy at my Mazda dealership today. I went in to get a couple of oil filters and antifreeze, I specifically asked for the "Thailand" filters as I didn't want the MV filters. He said they (the dealership) didn't carry the MV filters anymore. I asked why and he said the OE from Thailand is the better one. They must have had some experiences with the MV one to not order it in anymore. Good enough for me.
I picked up a couple of the Japanese made Roki filters for the turbo. Honestly I think the turbo denso made filters are better if flow is a concern. The Roki filters have 6 small round inlet holes, the denso has 8 oval , larger holes.
I understand the importance of flow on Skyactiv engines and appreciate your earlier post about shorter OCI. I wonder if there are two parts of the flow: fresh oil entering the top inlet holes into the filter media, and exiting through the inner tube/core/support. Do they both matter? 😅
Sure it matters but I didn’t take it apart, just an outside look and observation. The new filters look as well made as the sought after rokis.
