flat_black said:Cool, I'll have to stop by there tonight. Thanks!
here is what you need, left side 1/2" flare, right side is 5/8" flare on the top one, and 5/8" on the bottom one, the pipe I used is 1/2" SS
Just to let you know....Those pieces are adapters for FLexible Gas SUPPLY lines.They are only used to connect things like stoves and water heaters.Those flexible gas lines only run about a 1/2 PSI through them and have no heat applied to them. I dont see whey this wont hold up, but its possible that it wont. The only other thing I was considering was splitting the factory 626 or protege EGR pipe and adding the needed length by welding in a section...I am all about making things look factory.I am not sure if the 626 EGR pipe will work but I am going to do some research and maybe check this for myself.If your Dyno shows positive results then I will order my Intake Mani and I will order the 626 EGR pipe to check the fitment of with this set up.tekkie said:here is what you need, left side 1/2" flare, right side is 5/8" flare on the top one, and 5/8" on the bottom one, the pipe I used is 1/2" SS
tekkie said:yeah I was told the older mani would not fit now we know why![]()
I should be getting my dyno done on saturday
tekkie said:this company was having a dyno day on saturday, 55 bucks for 3 pulls, well I show up and they said its cancelledI asked if I could get one done anyway and they said no because they had 2 cars they were getting ready for Sema
this week they are getting ready - going to Sema so thats out of the question so hopefully I will have time to go next week
ND4MSP said:Thats kinda weak. What's a dyno session 1 or 2 two hours depending on your needs. Yeah lets turn buisness away and possible word of mouth buisness so we can tinker with our toys just a tad more.
