rchrist364
- Mazda 2 Touring Custom
I have H&R lower sport springs on my 2 and have major wear on the inside of my tires, are there any camber kits out there that will fit to correct the negative camber?
SPC also makes camber bolts for a lot less $$$$$ Available on Amazon. Part number 81250. Up to a 1.75 degree camber change.
Dropping the car causes toe-in which when combined with camber puts a real stress on the inside of the tires.
Fix the toe and you solve about 90 percent of the wear. Then you can put the camber where you want it for best bite.
John
