Mazda 2 H&R Springs, negative camber..
Going the opposite direction, here are a few pictures of the maximum amount of negative camber you can get with the H&R springs and the H&R camber bolts.
-Derrick
Okay so there's still a slight degree of negative camber but still better than mine. What about the back suspension, any noticeable camber difference?
The rear camber is -1.5 degrees with the H&Rs installed. The range spec listed for the 2 is -.5 to -2.5 for the rears. What is the front camber measurement of your 2?
-Derrick
