Mazdaspeed2oo35
600whp - 600wtq at 30 PSI
Congratulations to Pirana !!!!
Hey Buddie, Definately you have the most beautiful MSP in the whole freaking World, I dont think theres is a Mazda, to not say MSP so well done than yours, Congratulations for you hard work and Amazing Vision of what it is to really Make a Dream Car come true, Your car is Definetely a Sample of what an MSP can real be. a True Admire of your hard work. Mazdaspeed2oo35
And the Winner is ????????????????
Pirana said:Might as well try a shot at ROTM of May to celebrate the Modified feature,
Piranas 2003 Mazdaspeed Protg
<O</O
Exterior<O
</O
Fiber Images full carbon-fiber Evo hood<O</O
Xcelerated Concepts carbon-fiber trunk lid<O</O
AutoExe front lip & front grill<O</O
Carbon-fiber eye lids<O</O
Mitsubishi Evolution OEM full carbon-fiber wing<O</O
Mitsubishi Evolution OEM hood vent and grill<O</O
TCSportline dry-carbon F1 style mirrors<O</O
Protg5 fog lamp conversion<O</O
35% Llumar window tint<O</O
Silverstar hyper-white bulbs<O</O
MP3 amber side-markers (rewired to ON w/park lights)<O</O
JDM Familia badges<O</O
Lamborghini Diablo OEM air-horns<O</O
HKS steel license plate trim<O</O
Ignited Performance H4 Hi/Lo 6000K HID kit<O</O
Ignited Performance H3 6000K fog lamp HID kit<O</O
<O</O
Interior
Sparco red Torino seats<O</O
Sparco 3 cam-lock black harnesses<O</O
Sparco black Mugello steering wheel<O</O
Sparco Miata hub adapter<O</O
Sparco Grip pedals<O</O
Sparco Grip dead-pedal<O</O
Sparco e-brake handle<O</O
Sparco leather red stitch e-brake boot<O</O
NRG carbon-fiber steering quick release kit<O</O
Wedge Engineering seat brackets<O</O
ARC titanium shift-knob<O</O
Honda Civic Type-R leather shift-boot<O</O
Crossover Auto-spec 4pt. roll-bar w/harness bar<O</O
Carbon-fiber instrument bezel<O</O
Carbon-fiber glove box cove<O</O
Carbon-fiber arm rest cover<O</O
Carbon-fiber A-pillars<O</O
Carbon-fiber center console<O</O
Carbon-fiber radio trim<O</O
Custom center steering gauge pod<O</O
Defi BF series boost gauge<O</O
Defi BF series egt gauge<O</O
Defi BF series water temp gauge<O</O
Defi BF series oil pressure gauge<O</O
Defi BF series fuel pressure gauge<O</O
Defi BF series controller II<O</O
Defi BF series gauge hoods (5)<O</O
Defi VSD Concept HUD display<O</O
AEM UEGO wideband gauge<O</O
Auto Meter air intake temperature gauge<O</O
Auto Meter NO2 pressure gauge<O</O
Valentine One radar detector-hard wired<O</O
Niken wide-angle rear view mirror<O</O
Custom polished aluminum instrument rings<O</O
Chrome fire-extinguisher<O</O
Mental Addiction CNC aluminum door lock cover<O</O
Mazdaspeed OEM door sills<O</O
Mazdaspeed OEM white gauges<O</O
Mazdaspeed OEM floor mats<O</O
<O</O
Performance/Engine<O</O
NX N-tercooler bar<O</O
NXautomatic bottle opener<O</O
NX purge valve kit<O</O
NX carbon-fiber composite bottle<O</O
Mental Addiction MSP Jet-Hot coated tubular manifold<O</O
Perrin MSP front-mounted intercooler<O</O
Perrin custom billet fuel rail<O</O
NRG liquid-filled fuel pressure gauge<O</O
WRX 440cc injectors<O</O
Walbro 255lph fuel pump<O</O
Injen MSP cold-air intake<O</O
AEM dry-flow intake filter<O</O
Haltech E8 custom tuned by Crossover Auto<O</O
HKS EVC5 boost controller<O</O
HKS Super-sequential BOV type II<O</O
HKS limited edition D1 oil cap (authentic)<O</O
HKS limited edition D1 1.3bar rad cap (authentic)<O</O
Garrett GT28RS turbo*<O</O
Chrome plated P5 valve cover<O</O
Nology ignition wires-red<O</O
Nippondenso Iridium BKR7EIX<O</O
Castrol Synthetic motor oil<O</O
PWR P5 aluminum radiator<O</O
Spal 12 slim-line fans (2)<O</O
Apex-i turbo timer controlling fans<O</O
Samco red silicone radiator hoses<O</O
Samco red silicone vacuum hoses<O</O
WeaponR coolant catch can w/ARC cap<O</O
WeaponR crank-case breather filter <O</O
Optima red-top battery<O</O
Custom billet aluminum battery mount<O</O
Xcelerated Concepts custom hood shocks<O</O
T-Bolt clamps<O</O
AWR motor mounts<O</O
AWR custom aluminum baffled oil pan*<O</O
Street Unit custom billet motor mounts*<O</O
Kartboy shifter bushings<O</O
Kartboy exhaust hangers<O</O
Vibrant Performance 3 SS turbo-back exhaust<O</O
Vibrant Performance 3 custom cat-less downpipe<O</O
Rewired ground wires at water neck<O</O
Black reservoir cover sockies<O</O
Goodridge red stainless steel clutch line<O</O
Wiseco 9.1:1 forged pistons*<O</O
Pauter forged rods*<O</O
ACL rod/main bearings*<O</O
ARP head/rod/mains studs*<O</O
SR Motorsports adjustable cam gears*<O</O
Eibach valve springs*<O</O
Cometic head gasket*<O</O
Custom ground 268 camshafts*<O</O
Port and polished head*<O</O
Port and polished intake, removed butterflies*<O</O
Corksport S down-pipe*<O</O
<O</O
Suspension/Brakes/Tires<O</O
GT-Spec front strut bar<O</O
GT-Spec lower front tie-bar<O</O
GT-Spec front 4pt. ladder bar<O</O
GT-Spec rear trailing arms<O</O
GT-Spec rear V-brace<O</O
GT-Spec rear protective cover<O</O
GT-Spec trunk cage<O</O
Ksport adjustable coil-over<O</O
AWR adjustable end-links<O</O
Racing Beat front/rear sway bars<O</O
AutoX rear sway bar relocating kit w/bushing<O</O
Volk Racing TE-37 18x 7.5 +45mm offset<O</O
Volk Racing titanium black lug nuts<O</O
Volk Racing carbon-fiber low center caps<O</O
Toyo Tires T1R 215/35/18 tires<O</O
Rotora red 4-piston calipers big brake kit <O</O
Rotora 330mm cross-drilled/slotted rotors<O</O
Rotora brake pads<O</O
Rotora stainless steel brake lines (front)<O</O
Rotorworks rear cross-drilled/slotted rotors w/Goodridge lines<O</O
Hawk rear brake pads<O</O
<O</O
*denotes in the works<O</O
