Manifold bolts
bubba019
Mazdaspeed Protege
Hey guys, I'm getting a Steedspeed manifold and I wanna change the bolts that go to the manifold and connect to the engine. Any of you guys know the size of the bolts?
(dance)(piss)
go to *************.com and get the arp studs! there i a bit expensive but are well worth it!
M8 x 1.25 thread. On crossover auto's site it recommends certain lengths for the ARP's. I wish i would have had the cash to get ARPs. Instead i got stainless bolts same length as the stockers.
would you recommend heat resistant bolts?
yeah, i got bolts that were higher than grade 8 spec... you can't go wrong with the ARP studs though, if you can afford it. I kinda wish i had gone that route.
do it! u wont regret it! way less likely to break wen taking out aswell! u want the 38mm studs!
I'm about to pull my turbo and replace my studs as well. Considering I don't want to do this much work twice, I invested in the Arp's.
yes... i promise, you don't want to have to do this 3+ times....
Just quoting for research on this info 38mm
