ARunto said:
What's the difference between STX and STS classes?
This is the info on moutons.org but it gives a good idea about the differences.
All allowances in STS carry over, including street tires, emissions, etc.
All restrictions regarding body type carry over.
Engine size allowance: up to 5.1, normally aspirated and 2.0, forced induction (single turbo or supercharger).
Rim restriction: maximum width of 8", diameter/offset unrestricted. Tire restriction: max width 245 mm .
Only factory limited slip differentials (LSD) are allowed on AWD vehicles, as defined in Section 12.4. For AWD vehicles that did not come with any type of limited slip differential (including center differential or transfer case), a single aftermarket LSD may be added. 2WD vehicles may use any LSD unit.
High flow catalytic converters are allowed, but must attach within six inches of the original unit. Multiple catalytic converters may be replaced by a single unit, provided the single unit is within six inches of the original primary unit. The resultant configuration must meet Federal emissions standards at normal vehicle operating temperature.
Alternate motor mounts and/or engine locators (bobble struts) sold by the vehicle's manufacturer or their Motorsports subsidiary or affiliate ( Chrysler/Mopar, Toyota/TRD , Honda/Mugen, etc.) are allowed.
Alternate driver and front passenger seats are allowed, but they cannot be constructed of a solid outer shell and must have a suspended bottom cushion and be fully upholstered.
Brake rotors and calipers are unrestricted, but must attach to the original attachment points.
Additionally excluded cars: BMW M3 (E36 and E46), BMW M5 (all), Mitsubishi Evo 8, Subaru Sti.
