magnaflow exhaust
That is just what I remember.. Mabey it is bull-s***.
This cat-back... So it is a full replacement except the stock downpipe piece right? basically the best way to go about it because you dont have to mess with the o2 sensor or a check engine light right??
Krillin and my car were the prototypes. We both have the Protosport DP, and Magnaflow cat back. I didnt like the sound of mine with the DP. Too loud. And Krillin still has his, and seems to like it.
If you were to only install the cat-back exhaust from magnaflow... Would you have to splice in the o2 signal modifier to keep the check engine light from comming on?
i believe not. i think thats only for if you install a different header like awr or racingmazda.
Header?? I think you mean downpipe...
I think so too, from looking at pictures it looks like the magnaflow exhaust bolts up to the downpipe and the o2 sensor goes into the downpipe about 2-3 inches from where the cat back bolts onto.
A cat-back is after the cats...so since you don't touch them, you won't need to mess with any O2 sensor crap. If you got a catless downpipe, then you would need to.
um... the check engine light would only go on if you removed the cats, with a catless downpipe. Like I did. Shouldnt be a problem with the cat back
Lol, I was going to say something about that whole "header" thing. He may have been thinking of his car since his car is N/A.
Yea i forgot this was in the MSP section.
Dynomax is what I recommend for turbo guys!
If you want to have an idea of ho it sounds, download my videos.
My setup is a Spool turbo, 2.5inch turboback, NO CATS, only a resonator and a Dynomax.
Vid #1: from inside, spanked by Mustang
Vid #1: from outside
