Hello all,
So the past few days I've been having a very rough idle, to the point that the car actually dies while in neutral at lights every now and then, and I am unable to get more than 5PSI of boost no matter what. There is a CEL on that (I forget the actual code) says the MAF voltage is high. I have already pulled the sensor and gave it a good cleaning, which did nothing to help my problem. I have inspected (and will do so more thoroughly) the wiring for the MAF and didn't notice anything out of the ordinary.
Also probably worth noting is that I did leave my lights on the other day. I was able to get a jump and it ran fine for that one start-up, no CEL, boosted fine. After turning it off and starting it up the next day it started up fairly slow and the CEL came on (also my TCS light is on as well) which is when this whole problem started. I have tested the battery, and it tested as being fine, although it did have a slightly low charge of around 83%.
Not sure what else I should check, beyond just starting to replace parts. Any help would be appreciated.
Thanks
Thanks
