Ok, so I just made 250whp @ ~5K RPM hitting MAF voltage limit. 250whp is swell and all, but what bugged me is that I couldn't make power after 5K RPM due to the fact that my MAF freaked (says my OBD - II tool) due to the fact that it reached it's maximum voltage (4.7v?).
So in short, it kinda sucks that I can't rev my car out.
I need a cheap and EASY way to fix the problem.
I could go ghetto and wire a resistor in line so that it never reads past the point (we'll call it POINT X) that freaks out the MAF, now making the ceiling POINT X. Only problemn there is, that off boost, when I'm at say...2.5v, just driving along, it may now tell the ECU it's at say...2.2v, and thus run me lean. In short, I'd have to re tune my ENTIRE fuel map.
Ideally, what I'd LIKE to do is get a device that just acts as a voltage clamp. Something that inputs voltage and outputs the same voltage, EXCEPT in the case where the input voltage exceeds POINT X. In that case, it would simply output POINT X. Ya dig?
I could get a bigger MAF and retune the entire car, but that could be a PITA.
Any ideas?
Any ideas?
