Lug Nut Torque Specs for 08MS3 and 05MS3
ZooMIN3
Whip:01 Ford Focus;08 Black Mica MS3GT
I'm searching and can only find the wheel size/offset info on our cars. I need to know what are the torque numbers for tightening lug nuts for a 2008 MazdaSpeed3 and a 2005 Mazda 3s.
I've even googled it.... perhaps I've overlooked it, but someone who knows the torque specs, please help me out. Thanks.
-J
Proper Lug nut Torque
Per the 2007 Manual, page 7-11 the wheel lug nuts should be tightened to 66-86 ft pounds (89-117 newtons). This is the only reference in the entire manual regarding lug nut torque.
Cheers!
Peter
Per the 2007 Manual, page 7-11 the wheel lug nuts should be tightened to 89-117 ft pounds. This is the only reference in the entire manual regarding lug nut torque.
Cheers!
Peter
Actually its 66-86 ft/lbs. I think maybe you meant Nm? So many crazy torque readings...
Cheers!
Peter
lol thanks!! As Vindikacione pointed out, it is 66/86ftlbs, in the paranthesis. Thanks again!! You know, I did look over it in the manual... (hand) thanks again!!
Thanks guys - I updated my original post just incase someone looks at it and stops reading. It is interesting that some manufacturers specify numbers in the low hundreds.
Peter
