lucky 7s?
hey i was jus wondering if 17x7 would fit the 2.3s. im lookin at the volk ce28n or any replicas of it also.
yes, 17x7 would fit, however, it does depend on the offset. do you know the offset for that rim?
42 offset is HIGHLY pushing it. I believe there are people running that on here (possibly do a search to find out). I would definately say if you find anything over 45 you should be safe. Or you could do what I did and find a shop that will machine them to a better offset (mine were machined from a 42 to a 47)
thasilver3 said:
tph wat would u say is better wit a drop the 17" or 18"rims ?
either will be fine. when you are dealing with the drop it will come down to tire size/offset more than rim size. I have sportline springs with 18x7.5 rims with a 47 offset and am running 225/40r18. I dont have any rubbing issues. what springs you running/planning on?
yeah, sportlines are definately very low and take some getting used to. and make you hate speed bumps. I would say that especially with a drop 42 will cause some rubbing and you should try to find 45+
