- Plano, Texas, USA
It says "Genuine Mazda Fluid (0000-77-XG3A) Silicone Brake Caliper Grease - 3 oz. Tube", but the picture shows Motorcraft by Ford with the same XG3A part number (sorry for the huge pic):I can't find my little tube of brake lube, I believe it was the Permatex Ultra Brake lube, the green stuff. Anyhow, I was searching around and many people on the internet have suggested to use silicone brake lube so as not the effect the rubber seals at all. I browsed Amazon and came across some Mazda Pure silicone Brake caliper lube, part #0000-77-XG3A. A little pricey but at least I know it's what mazda recommends to use so it should take all guess work out of the debate.
if your prefer silicon grease for caliper pins like Mazda Service Manual specified, here is an alternative - Sil-Glyde Silicone Lubricating Compound recommended by Skorpio:
I only recommend synthetic lube specifically made for high temperature brake usage. I have used Sil-Glyde for many years without fail. If you go to an auto store, they should have it, or similar on their counter.
