Low Fuel Light
PWR SHFT
Contributor
2005 Mazda3s
Does anyone know how much we have in reserve when the yellow light comes on indicating low fuel? It came on when I got to work, and I want to know if I can make it home where the gas is cheaper (33 miles).
Thanks!!
It's different for different cars but mine is usually around 1.5 gallons or so.
hehehe, funny you should mention it.....i've made it more than 40 miles with the light on, for the exact same reason. I work right across the street from an airport, so gas is crazy expensive within the area.
I keep close track and it's always been over 2 gallons plus. I figure with my foot in it I still get 24 mpg so that's almost 50 miles with the light on. I have also notice the fuel pick up must be in the front of the tank. I've parked in my driveway a few times with my fuel light on and the car would not start until I coasted out of me driveway. :)
My light came on once and my car only took 11.5 when i filled up. since our tanks are 14.5 gallons...well, you get it
yeah i would say 50 is about right with a bit to spare since i have filled up after driving around for a while with the light on and still only but a bit over 12 in....
yep...50 has been my rule of thumb? Rule of thumb? What kind of expression is that anyway? (eyeballs)
Rennoc said:
.... your crazy.. how did you even find that, i must admit impressed. The 50 rule seems a little high to me because i dont like to run my mazda on pure fumes but 40 maybe a little over ive done a couple of times so i know that that is fine
how much gas did you put into your car after running 40miles after light came on? around 12.5 i would think... you still have 2 gallons left... not fumes... the gas lights just come on hella early.....
Look at it this way:
Once you're below about 1/4 tank, your fuel pump is exposed to the air.
When the pump isn't surrounded by fuel, it generates more heat.
More heat = bad for electrical components, especially high-speed motors.
The lower you let the fuel go, the more exposed your pump is.
The more often you run your tank almost dry, the shorter the life of your fuel pump is gong to be.
In a nutshell... fill it up before the light comes on!
I never do, I always let it go until the neddle is under the red line. I don't have the light anymore cause or the gauge overlays. I know I shouldn't, but I can't help it.
To add on to goldwing2000, electric in-tank fuel pumps are cooled by the gasoline in the tank. Continually running your tank empty, could cause premature fuel pump failure. I don't normally do this on a regular basis, but once in a while you can't help it.
This could be why the light comes on so early - to keep the pump submerged and cool. Depending on the shape of the tank, 2 gallons could be enough to accomplish this.
goldwing2000,
got a picture of the tank?
Hmmm... don't recall ever seeing one but I'll look through the service manual. A seriously doubt 2 gallons will keep the pump submerged but it's worth looking in to.
I also have to concure with goldwing. I had an old Volvo 240 which I ran the tank dry (fuel gauge didn't work). That killed the fuel pump, mechanic mentioned that the pump on the Volvos were sensitive to running dry and if you did it would kill the pump.
I would imagine that the fuel pumps 20 years later from Japan are more robust, but increased heat and less load (pump running but no fuel) would cause problems.
good points, i guess i should stop running mine to E every time then.... just the way i am, like to eek every bit out of every tank.... eh oh well sounds like i should try and change that habit...
i'm just frick'n lazy. I tell myself I need to get gas and before I know it I'm trying to remember what my mileage was when my light came on. (boom06)
Actually, I don't......I'm kind of a retard when it comes to math..... (stoned)
