Low Beam HELP!!!
andrew.savage
2006 Mazda 3 5-Door
Alright, so i bought some Luminics H7 low beams for my 2006 mazda 3 hatch. I've been waiting for a week or so and i finally got them in the mail. Here's the problem. When i took them out to see if they will work, the bulb itself does not fit into the wire bracket that comes from the car. I haven't even gotten to taking the original bulb out because when i line up the female part and the male part from the bulb, they clearly will not fit, the bulb plug is just not wide enough to fit correctly into the wiring. My question is, do 2006 mazda 3's take H7 Bulbs and does anyone think that i am doing something wrong?
I do believe that the 06's take H7 bulbs. I don't think your doing anything wrong but I would have to see it for myself. I'm sure someone on here has some insightful info for you. Good Luck and post some pics when all is said and done.
Ranger
sorry about the lack of info, i'm at work so when i get home around three i should have pics up for you guys to explain better.
