evanisonfire
ya well i will do the leakdown forsure. so worste case scenario its the turbo??
ehh, I wouldn't take the oil cap off while it's running for long
a better test of that is to just unhook the hose from the valve cover (on the driver's side) to the intake...but not sure how that is really going to tell you very much, as the pcv could cause a little back pressure to the turbo but not enough to put that much oil in the intercooler piping
this can be 1 of 2 things. first off, and the one you dont want, is the oil seals in your turbo could be bad which would mean you need a new turbo. secondly, a weak point on our cars in the pcv valve. it just cant handle boost and because of this when you boost you presurize the crank case threw it cause it cant close and that pushes vaporized oil out threw the big vacuum line from your valve cover to your intake. its then sucked in by the turbo and deposited in your charge pipes if it doesnt make it all the way through your engine. i had oil in my pipes so i upgraded to the millenia s pcv but it still cant hold up but no where near as much oil as you. i also have a bad wga so i havent been getting on my car in a long time so my oil is gone. this weekend im going to try and rig a 96 supra tt pcv valve on my car. if i were you id try that and see how it works out cause you dont want oil filling up your pretty new front mount. you could also put a breather filter on your valve cover but with a bad pcv youll have oil coming out of the filter and spraying your engine bay. BUT, if you get no more oil in your pipes than you know its not your turbo. can also try catch cans too.
