Looking for more power, what would you do?
I read a really interesting article about air flow and hood scoops... The short version is, a guy cut a scoop into the front corner of his hood, because he had a TMIC mounted kinda where our battery is (this was on a 90-something Nissan). He did some testing with pressure sensors, and due to the aerodynamics of his car, air flowed out of his forward facing scoop at ~50mph, hence his intercooler was being heated by engine bay air instead of cooled by ambient air. Sounds crazy, I know. I'll try to post up the link.
Basically, the MS3 is set up from the factory with the hood induction and underbody tray; that's probably the optimal system for cooling the TMIC. I'd be cautious with cutting or adding scoops.
edit, found the article. Hopefully it should be attached as a .pdf. Check out this quote:
So if you’ve added a bonnet scoop to pick up air – or you have enlarged the standard scoop – it’s quite possible that there’s a pressure build-up under the bonnet which is dropping the efficiency of your radiator, intercooler, oil cooler and/or air-conditioning condenser. Get rid of that pressure build-up and all of the above will work better...
The ram air system for our car is pretty cool. ha. but the stock mounted unit seemed to run hot to me. after upgrading, all better. But a properly sized front mount is surely the best solution.
