- 2001 Mazda MP3
hows it running ahmad?
i wonder if my haltech has that hookup. its 2000 miles away so i cant check ATM
pdhaudio83 said:hows it running ahmad?
ELEmental59437 said:The settings are pretty self explanitory on the Haltech Closed Loop setup. I connected the 0-5V wire up to pin 2 on the Haltech. Juan had to send me this wire since it was not initially included in my setup. I set the Closed Loop to work at less than 25% throttle and it seems to be the magic number on that. I am currently at 8 engine cycles before correction and it is pretty stable as far as staying stoich at cruising speeds. I am taking out up to 19% fuel at times, I can just imagine how much gas I was wasting before. I will take a screenshot of the screen and my settings as soon as I figure out the idle closed loop deal.
Ahmad
glyph said:If your haltech came with a grey shielded cable with two wires hanging out of the end, that's your closed loop input. If you have it you probably just tucked it away. At least that's how mine looks.
LinuxRacr said:Well, my car sits disabled. We know that the E6X is not working correctly. I Ahmad put my E6X in his car, and loaded his map. It started doing the same thing it was in my car. Started heating up the coil on the driver's side (coil 1), and there was this high-pitched whine that stopped when that coil was unplugged. We put his E6X back in his car and all of that stopped. Looks like a driver or something is out.
Anyone talk to Juan lately? Can't get a hold of him.
TurfBurn said:did you guys try putting Ahmad's E6 in your car and see if it runs then or not?
LinuxRacr said:Yeah, I think I may be screwed. I have to send it back for reapir. This means being without my car. I can't do this...
