Linear Logic Scangauge Xgauge Programming
They should work for any Mazda3. There are a ton of different cars using this little gauge. It's been a long time since I set mine up, but basically, you input the engine parameters yourself (I think) and it will take the data it gets from the OBDII port and output whichever 4 things you want to display.
ya i figure about the basic stuff, but i got this cuz dashhawk is no more and the edge insight suck for tucks only really, i just didnt know about the codes haha
The codes can be a little tricky, but you'll get the hang of them. The only drawback to this unit for me is that to get the fuel efficiency related stuff you have to manually tell it every time you fill up, which can be a bit of a pain.
Here are some confirmed working gen2 codes for you guys...
Knock/Fuel pump (at rail)/A/F
Knock Retard (KR) (in degrees)
TXD: 07E0221746
RXF: 046285170646
RXD: 3008
MTH: 000700020000
NAM: KR
Fuel Rail Pressure (PSI) (Displays correctly now!!!)
TXD: 07E022F423
RXF: 046205F40623
RXD: 3010
MTH: 001D00140000
NAM: FRP
Air to Fuel Ratio
TXD: 07E022DA85
RXF: 046285DA0685
RXD: 3008
MTH: 001700140000
NAM: A/F
