Leftover parts (Perrin, 440cc injectors, SSAFC, lugs, stock turbo etc.)
Hey guys, I recently picked up a Mazdaspeed 3 so I will not be needing any of these parts. Of course all prices are OBO but I feel like I have priced them competitively with the going rate for used parts. Thanks for looking.
Subaru WRX Top feed 440cc injectors with new O-rings.
SOLD
Perrin Fuel Rail
Purchased from member and never used. Not 100% but I don't think it has ever been used. Comes with all braided lines needed for installation
SOLD
Turbosmart Manual boost tee (Black)
SOLD
Stock turbo removed because of oil blowby
No shaftplay but I am selling so someone might want to get a new center housing or whatnot
Sold
High quality silicon vacuum lines
enough lines to replace ALL vacuum lines on the MSP. This isn't cheap stuff and never used. I can't remember who I ordered from but I know it was almost $100.
Sold
Signature Sounds snotbox (catch can)
Has AN fittings ready to be installed on your MSP or Protege. Has my username painted on the bottom but you can barely tell
Comes with clamp and bracket to install. has a dent where it was tightened during install
sold
DDM tuning 6k HID kit for MSP. Never used but needs 1 ballast to be complete. Also could be used to replace burned bulbs/ballast
Sold
AWR Engine motor mount inserts
Never used only opened to check parts
SOLD
MSP OEM MAF
Not sure how many miles. Guarenteed to work
Sold
MSP Primary o2 sensor
sold
Corksport Stainless Braided Clutch Line
Never opened
Sold
Muteki SR48 Open ended Neo-Chrome lug nuts 12x1.5
SOLD
Rotary Rasp Red LED under dash kit
Normally used in rx8's but just uses 12 volt power
$30 shipped
Factory shifter and bushing
SOLD
SSAFC with disk and USB cable
I believe it is a Version 2. Maybe someone can help me out with this. I have never used this, was bought from a member here.
SOLD
Vibrant Black Vacuum block
Has all of the pieces to close vac ports
$40 shipped
For the split second the v1 only have the vacuum/boost line and 1set of wires. V2 avec V/B line and the same wires set, but 1 wire set more for wideband and other input.
Thanks, I thought it was a V2 but wanted to verify.
Payment sent for lugs. Ship it the cheapest possible way via USPS. I'm gonna be training for the entire month of July so I'm in no rush.
Can you give me more info on the turbo? When you say blowby do you mean the turbo seals are leaking? Are you selling a waistgate actuator with it?
thanks
Turbo was leaking oil through the seals. Wastegate was removed. I just figured someone could use it to swap the center housing.
All prices are obo so PM me!
SSAFC STILL AVAILABLE!!
Get the total package with 440cc injectors and I will make you a deal!
10$ shipped for the braided clutch line. PM me if your ok with it and ill send money.
$20 shipped. $10 wouldn't cover shipping, a box, and gas.
