Need help. since yesterday my turbo P5 wants to run LEAN only on HalfThrottle to WOT. Partial Throttle will run RICH all the time. But as soon as I ask for more power, It drops down to LEAN 16:1 the car buckles a bit when building boost, and acceleration is very poor, It even feels like the car is braking instead. Partial throttle boost accelerates faster than WOT.
How I know Im running lean?
Greddy A/F is showing 14:1-16:1 ratio and EGT starts to climb faster.
My current setup is:
Boost line connected from compressor to Wastegate thru the JoeP MBC and a T connection to the FMU BEFORE the MBC.
After doing some testing, disconecting the MBC, only conecting the Compressor to the FMU and wastegate still the same. But at 4.5psi runs rich, but as soon as I raise the boost to 6psi or more, WOT will run LEAN.
Last test I did, connected the FMU to the manifold vacumm, where I feed the Signal Modifier and Boost gauge and now i have better numbers but they are near 13:1 A/F.
All 3 weeks before i was running very rich, Greddy A/F was showing 8:1 - 12:1.
Any suggestion?
Any suggestion?
