Mscurfield
Hello everyone, I'm actualy posting for my sister as she needs some help with her 2003 MSP. The problem is the exhaust mainfold keeps leaking, and there are no cracks in the manifold. It seems like the bolts keep coming loose some how. She has had this problem fixed by the dealer under warrenty twice by them replacing the exhaust manifold gasket and she has had to pay out of her pocket once as well so thats been chaged 3 times in total. Now its leaking again
Is there a design flaw with the bolts? Has anyone replaced the bolts with Studs and nuts? If you have, how well did it work and do you have anymore info on the sizes and such that are needed. Also the exhaust manifold gasket that was used are the OEM gasket. I did search but didn't come up with much direct info on the bolts or OEM gaskets.
Thanks in advance for any info you can provide
Cheers MikeS
Cheers MikeS
