launching help
i just went for my first time two weeks ago i had 5500 kms on the car. and launching the mazdaspeed3 is not a piece of cake thats for sure. you cant just dump the clutch you have to ride it a little bit in first gear to minimize the spinning. and these cars spin like crazy if you dont control it. just like "bykeryder4 life" said he is dead on. my best time for the first time at the track with my ms3 was 14.4. it was my friends third time with his speed 3 and he got a 13.9. i have been driving manual for a year and a half.good luck
it's got a sweet spot, that's for sure... coming from RWD cars, the speed is quite a bit different... first and second are pretty tricky in mine, even with little to no mods.... i think a stickier set of just a bit wider tires would help a lot...
get the feather out quick, and have the RPMs matched to the traction you are getting, and it will flat SCOOT. at a track, you have a bit more consistency, so you should be able to get it figured out...
on a smooth asphalt road (less traction), in first or second gear, ours will confuse the traction control, and just light the tires up... no kidding. does anyone else have this happen? if you get it right on a good concrete road, it grips, and just flies out of second into third.... it's a lot of fun.
make sure you aren't running too much or too little tire pressure, prepare to stiff arm it to keep it straight as it fights for traction, get the clutch all the way out as soon as you can, and be sure to shift before it gets to the dead spot. which is VERY quick in first gear...
like my old nova, going from first to second, i like to pull on it in first a bit, just before the quick lift-shift-stab. aiming the shifter into second.
the hard part is judging how much traction you are getting. i have found mine will hook up better with another big guy like me riding. it seems to even it out a bit.
i don't launch mine hard. i just think it is punishing the drivetrain for no reason... i just try to get into third as quickly as possible!! but at the track, go for it!
you ran a 14.4? was that stock?
and thanks man
I actually went to the tracks last Saturday. I punished the hell out of my tires (stock Potenzas). The few good launches I had were meaningless since it was over 100 degrees with a ton of humidity (don't know how much but guess is 35%+). My BEST time was 15.2! I was having such a crappy day since I was there to beat my friend with the Mach1, who ran a 13.8 best. I have a SRI and TBE and didn't even manage to break into the 14s! ARGH!!!
that sucks dude. better luck next time. its nerve wracking on the track wanting to do good and everyone watching. 13.x is doable. just concentrate and keep an eye on your shifts and you should be able to get there...esp. if the weather isnt so tough.
man i know what u mean i ran it yesterday, after everyone's advice. i ran a 15.0. i was bogging everytime at launch. i'm completely stock. it's all in the launch and good shifting...which i can't seem to get down right lol
very dumb question, coming from someone who drives automatic.........is there anyway to launch using the shiftronic (spelling?) feature?
i believe shiftronic is a "type" of tiptronic named shiftronic by....hyundai? anyways i cant see why you wouldnt be able to. if i were you though i would go from 1st gear to drive instead of shifting through the gears via the autoshifter. then you only need to shift it once and you auto can do the rest.
