This thread will be dedicated to the FACTS of which larger injectors work for our Protege's. No off-topic chitter-chatter in here, just answers, and legitimate questions. Those who are running larger injectors post your specs, and how you installed them.
The stock injectors are 280cc injectors.
I know for a fact that the 2nd Gen S5 RX-7 (non-turbo) 460cc injectors will work on our cars WITH the proper engine management to control them. These injectors are longer, so you will have to double up your fuel rail spacers, and grind the lip away on one side of each of the spacers. You will then need to put the newly made flat surfaces together. Use black electrical tape. It may be a good idea to source longer bolts to screw in the fuel rail. They plug right into the stock harness plugs too! BONUS!!
Here are some pictures:
Installed:
Installed:
