Larger gas pedal?
Kaidao
Does anyone know where I can purchase a larger gas pedal? I want to replace the stock one with a wider one to make it easier to heel-toe. Anyone have any ideas?
pepboys, autozone, advanced auto parts...they all pretty much have a "rice" section with floor pedals. or maybe you just need different shoes
+1. The pedals are close already...
I can already get the side of my foot jammed under the gas pedal while braking and brake pedal while on the throttle. My first question when I got my car was "is there anyway to space the pedals out" not "is there a way to get them closer" ;)
To each his own and do what works for you. I would say look for aftermarket pedal covers. They should give you the extra you are looking for.
I don't have huge clodhoppers (size 10), but my feet are wider than average and this car has been the easiest to heel-'n-toe of any car I've owned (stock pedals, of course). I had AutoVation pedals on my last car and those were fantastic. If they don't offer a MS3 application, perhaps Sparco does.
There is a guy that makes custom pedals. I don't know if he still is. I originally saw it on Rotus' car. He has the wider gas pedal.
attachment.php
I liked the idea so I got one a while back too.
He does still make the pedals, however they're a hobby that he does in his spare time so turn around can be slightly slow depending on his work load at his real job. I also have his pedals..... though I have the brake/clutch/deadpedal too.
Please ignore the dirty floor.
That looks really good. How much did they cost you?
Hmmm, I want to say he's selling the accelerator pedals for $25 and the brake/clutch for $30. I got a discount because I was a trial person for the '05 model (the pedals are different from '06+ models)
you know what they say about people with wide feet...
If the gas pedal was a little higher, it would be perfect for me to heel-toe... The side spacing is perfect, but the gas pedal is just a touch too low for me... My S2K had the best pedal placement from my experience. Hmmm... wonder if I can make the gas pedal a little thicker...
If it is just accel pedal height.....You could just add a few fender washers/standoffs between the accel pedal assembly and firewall. There are 3 threaded studs that hold the pedal assembly to the firewall. Just remove the nuts and add about a 1/4" long standoff between the firewall and the pedal assembly, reattach the nuts and you should be good to go.
I will try this. Yeah, I'm mainly having problems with the gas pedal being too low for it to be comfortable heel-toe-ing.
...that they wear wide shoes?
On pedal topic, I end up sitting at a stoplight a couple times a week mistakenly revving the engine because my foot is pushing both brake and gas pedals before I notice it. (hand)
Hopefully I can use that pedal proximity to my advantage once track season rolls around.
