phunky.buddha
Booga Booga?
- DFW TX
- No mo MZ5 want MX5
So my wife's 5 has dead rear shocks... I want to lower enough to even up the gap, and add some firmer shocks for better control. At the $1000 and under range, I see these options as my best path forward:
Koni Yellow + H&R, about $900
Pros: proven shocks, proven springs, adjustable rebound
Cons: no camber adjustment built in, can't change ride height if I'm not happy with the out of box settings, rear rebound adjustment sucks
BC Racing, $1000
Pros: proven (sort of) shocks and springs, separately adjustable height and preload, adjustable bump/rebound
Cons: no camber adjustment (per BC's application guide), bump/rebound adjustments locked together
Yellow Speed, $950-ish (thought I saw $800 once before, anyone help here?)
Pros: front camber plates included, cheaper if I can find the $800 price deal
Cons: not well known yet
So has anyone had the chance to drive two or more of these setups side by side to compare? I'm no stranger to decent suspension setups:
Had these on my Civic along with a few others in previous iterations
Have these on my S2000, WAY beyond Koni Yellow and BC/Yellowspeed/whatever cheapo stuff
I'm trying to get the 5 to be a lot more stable in transitions and high speed sweepers. High spring rates are good as long as the damping is there to back it up and smooth things out. Harsh is not good (yeah, I know it's subjective) since the kids (4 months and 3.5 years) ride in this car- but the wife does prefer to know what the car is doing rather than float over everything unaware.
The engineer and track junkie in me wants to go with the Konis and H&R springs, but the features on the Yellow Speeds (camber adjust, height adjust) are really attractive for the price. Anyone remember an $800 deal somewhere? The BCs are a little more, but I know they're semi-proven on quite a few different cars. The tires will end up being 235/45-17s of the UHP or better category- maybe some Hankook V12s or something.
What would you guys grab in my situation? The 5 will probably never see a track, but it IS driven quite aggressively. I try to match (try being the key word) the pace I run in my S2000 on my daily commute, but sustaining 1G+ in turns is not something the 5 is capable of. Yet.
Help?
BC Racing, $1000
Help?
